Aktuelle Zeit: 18.10.2026 16:48
Ein neues Thema erstellen Auf das Thema antworten  [ 56 Beiträge ]  Gehe zu Seite Vorherige  1, 2, 3, 4, 5  Nächste
BeitragVerfasst: 08.01.2007 17:43
I want a TUV approved headlight because the glass quality is a little higher, also has the hole for the parkling light. I am not looking for aftermarket, OEM only. I do not need a certificate. As long as the lens has the TUV marking, I am fine with that. So, all I need is a dealer who can ship to the US.
BeitragVerfasst: 08.01.2007 17:53
i cant tell you that i'm sure on this, but my feeling says that if you would order from a swiss dealer that there won't be a TUV mark on the lense but a E4 for the swiss euro norm...
so if you really need this TUV mark you'll need to find one in germany!
but if you'd like to take a look heres my dealer i usually go to you can call him on 0041 26 496 3373 or on the net www.skm-sport.ch
check him out or ask me if you want to know more
buzz
BeitragVerfasst: 08.01.2007 17:58
Thanks Buzz, I'll use that if no one in Germany wants or can help. I appreciate it. :)
BeitragVerfasst: 08.01.2007 18:06
ain't a prob
good luck at searchin
have a nice day
BeitragVerfasst: 08.01.2007 19:34
Hi William! Look for the german part number and order the parts with this p/n at your local dealer. This should be the easiest way. I think someone in here can give you the link for the part numbers... Best regards, Andreas
BeitragVerfasst: 08.01.2007 19:59
das wird kaum hinhauen, sonst könnte man bei uns auch einfach den schwarzen klx-tank kaufen...
desweiteren glaube ich nicht, dass sich die Scheiben der Scheinwerfer unterscheiden, schließlich gibts nur noch EU-Modelle und keine länderspezifischen mehr
hab grad keinen bock auf englisch zu schreiben :lol:
BeitragVerfasst: 08.01.2007 20:30
Hi William, do this: www.suzuki.de --> Händler --> Motorrad. Then fill the single numbers 0...1...2...3...4 etc in the field "Suche nach Postleitzahl". That's all u need.
BeitragVerfasst: 08.01.2007 20:39
Staubteufelchen hat geschrieben:
That wouild be best, but, I do not have the part number for a German Headlight Lens Assmebly. In the US, the part number is
35121-12EA0 -"Unit Assy"
and costs (Dealer list price) $77.91 US.
If you can get me the German Part Number equivalent, I'll see if I can order it here. I would be surprised if I can place an order for a part used in another country but you do not know unless you try.
Regards,
Will
Zuletzt geändert von William1 am 08.01.2007 20:47, insgesamt 1-mal geändert.
BeitragVerfasst: 08.01.2007 20:40
Johnny hat geschrieben:
Sorry I cannot read German. :(
BeitragVerfasst: 08.01.2007 20:41
Turi hat geschrieben:
Are these numbers supposed to be the part numbers or is this a postal code?
BeitragVerfasst: 08.01.2007 20:46
William1 hat geschrieben:
these are the first numbers of the postalcodes, which have 5 numbers at all. first number is ok to find the dealers. so try "0" to "9". most of the dealers have a homepage and emailadress.
Zuletzt geändert von Turi am 08.01.2007 20:48, insgesamt 2-mal geändert.
BeitragVerfasst: 08.01.2007 20:47
Postal Code
http://www.freerun.de/mitfahrzentrale/g ... nkarte.gif
Gruß Hubi
