Aktuelle Zeit: 14.09.2026 04:32
 Betreff des Beitrags: About Dr350 wheels on Drz?
BeitragVerfasst: 02.03.2007 15:19
Hi german guys,
First of all excuse me because I don't know German and I'm writing in English. I just want to know if the wheels and hubs of Dr 350 (or Dr 650) fits the 2001 drz400s.
Thank you,
Onur
onuro
BeitragVerfasst: 02.03.2007 16:36
Hello Onuro!
At first: welcome to our Forum - it`s the best Forum of the world! :D
And second: sorry for my pupil-english, I`m whitout training... :roll:
But I think that the wheels and hubs don`t fits. Becaus there are different chainweels and breakdiscs- so I think that even the hubs must be different. Mabye you can exchange the rims, but I don`t think it make sense. :wink:
What do you want to do?
Many greatings Bob
BeitragVerfasst: 02.03.2007 17:06
See Topic
http://forum.drz400s.de/portal/viewtopic.php?t=1067
according to Herbrenner:
"Passen tun auch die Felgen der DR350 P (Sportversion ohne Rückdämpfer), mußt halt Buchsen drehen. Die Felgen der älteren Husabergs (vor der KTM Zeit) könnten auch evtl. passen ist zummindest die selbe Nabenbreite Bremsscheibe zu Kettenrad.
Vorne passen fast alle Felgen der RM -1999 sowie die Felgen samt der Bremsscheibe der Yamaha WR´s400/426"
Which means that you can use the front wheels of the DR350, also the rear wheel but only from the DR 350 P (Sportversion without damper), and you need an adapted rear wheel axis spacer. :wink: :lol:
Yes, brake disks and chain sprockets are also different.
BeitragVerfasst: 02.03.2007 18:01
I'm using the rear wheel of a DR 350 without damper, you need it complete because you can't change the brake disc (4 holes DR, 6 holes DRZ). On the left side DR distance part on the right side DRZ distance part + 1 - 1,5 mm distance washer on each side.
The DR's all got the same swingarm, so I think you can use a rear wheel with damper too - but I haven't tried so I'm not sure.
In opposite to franck I would say that you can't use the DR front wheel - I tried but it didn't work because the DRZ front axle is thicker than the DR axle and there is no bearing with the outer radius for DR AND inner radius for the DRZ axle. ( so I'm using the complete DR front in my XT 500 )
hope you can read my english for runaways :wink:
